yea thats why I asked my questionYou did not post enough pics of the labels on your oil container. It is my understanding that many 5W-x oils are 'energy conserving' which means they have additives incompatible with a wet clutch. 'My understanding' does not mean your oil is that type.
The container should say it meets JASO 4T service classification MA, and the oil weight should be SAE 10W-30. (That's a quote from the Honda service manual). You can read more opinions here:
Recommended Oil? | Cleaning, Oil, Maint.
Hi, I'm a new member and have a 2005 ST1300 using Rotella 6 for the last 20K miles. I just saw postings about issues with the Rotella 6 and looking for some feedback on a good replacement option. Thanks, Mikewww.st-owners.com
is it synthetic or semi synthetic required. it seems to be a very vague area. dont know why honda cant just tell what oil to use
They do, very clearly- See the attached.is it synthetic or semi synthetic required. it seems to be a very vague area. dont know why honda cant just tell what oil to use
Shame on you sitting by and eating popcorn. Mines heavy on the salt.
Well, Honda does. It either meets the quoted specs or its Honda GN4. Take your pick. IIRC, the weight oil you showed us - 5W-30 - is not shown in Honda's owners manual or service manual. Therefore, the simple answer to your question, "is this oil good for ST1300?" is 'NO'. A nuanced answer is going to be, you will probably be hard pressed in 200,000 miles of regular oil changes using your oil to discern a difference in the engine's performance or wear compared to another ST that used the recommended oil. That is assuming all other maintenance procedures are rigorously followed.why honda cant just tell what oil to use
They do. It's in your instruction manualis it synthetic or semi synthetic required. it seems to be a very vague area. dont know why honda cant just tell what oil to use
but not for bikes with "catalytic convecters".Never heard of this brand before. That would cause me to question the value. It seems to check the boxes as far as the specs go, except, it states that it is suitable for bikes with wet clutches but not for bikes with "catalytic convecters". The ST1300 has Catalytic converters. Maybe I am being a little too cautious, but I wouldnt jump to save a few bucks with this stuff.
