El Guero
V4 *****
I see some on ebay but I was hoping somebody would tell me they bought some recently that worked well.
Dave,
The PAIR system is for emissions. Pumps air into the exhaust at the cylinder heads. Those pretty chrome tubes that attach to the heads that you can see by the valve covers pass air from the pumps (under the carbs).
I pulled the entire PAIR system off while I was doing my cruise control install, made my own block off plates, put some red high-temp silicone on them when installed and have had no issues.
If you are going to pull the carbs, make sure to order new carb boots (isolators?) before you do. The originals will probably be brittle and break into pieces when you pull the carbs.
Haven't had time to install all of them yet, but I put one of the blocking plates from 6sigmajetkit on ebay on my bike. They aren't the fanciest things ever, but it appears that it will work fine. You will have to make sure you re-use your old gaskets or order some new ones though as the kit doesn't include any of those.
My pair removal page. http://koczarski.com/ST1100/PAIRremoval/PAIR.htm
Thanks for putting together that page. The link to the carb removal is dead, however. Any chance you still happen to have that?
