What is the best tire pressure for Pilot Roads. Found an ST1300 tire pressure specification of 42/42 PSI. Is this good for these tires. Do you run different pressure when touring fully loaded with gear?
trueblu said:What is the best tire pressure for Pilot Roads. Found an ST1300 tire pressure specification of 42/42 PSI. Is this good for these tires. Do you run different pressure when touring fully loaded with gear?
crazykz said:I run 42 and 42. The parts manager at the shop where I take my bike rides an ST and he swears by running them at 46 and 46. I don't share his feelings on it but I thought I would share them here for anyone that's wants a different opinion.
Curt
Just mounted new PR4s. Feels good running 42/42 psi. May drop a few psi when weather gets warmer. Beats the heck out of my old Bridgestones. Will check in later after some more miles.What is the best tire pressure for Pilot Roads. Found an ST1300 tire pressure specification of 42/42 PSI. Is this good for these tires. Do you run different pressure when touring fully loaded with gear?
This might be a record for reviving a zombie thread!
Sounds to me like the 42's have it.![]()
There is a LOT I don't know about tires. The tire pressure in a bike tire has a big role in the size of the contact patch. And I've not seen anything about changing the tire pressure for a heavily loaded bike. What you say makes sense, but I'd do some research before I added more than a pound or two.My understanding of appropriate tire pressure is that it's based on the weight that they need to carry. Even for a car, they often have 2 different recommended pressures depending on whether or not the vehicle is is loaded or not.
If the weight of the vehicle is a determining factor (and I assume it is), the 42 PSI is a starting point for typical conditions. When I have a passenger and luggage, I add a little more air (about 45 PSI) because that makes sense to me. I'm sure I'd be fine with 42 PSI, but a few more pounds of pressure may give me longer tire life when loaded and I doubt if it could hurt.
Well, 42 is the answer to everything.Sounds to me like the 42's have it.![]()
