Hellos,
I am changing brake fluids, and in the front brake master cylinder a loose part lay. In the fiche it's called "protector", part no. 45512MA6006 . See image for photo.
What's the purpose of it and how should it be mounted?
As for the purpose... it covers the (fluid) return port of the MC (leaving room for fluid return at the same time). The usefulness of it... mostly when doing MC work (changing fluid, bleeding, etc.) as when (rapidly) releasing the lever fluid will squirt out all over the place as I found out several times while working on hydraulic brakes/clutches.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
