Mountain Mike
I frequent the IBA Motel
I read on the Speedbleeder website to remove my bleeder and compare it to this website http://www.speedbleeder.com/News.htm before purchasing a Speedbleeder.
So I assume I will remove a bleeder from the front brake and look at it before replacing it.
Is there a problem with this so long as I don't touch the brake lever?
How many bleeders does an 1100 have? 3?
Are there bleeders for other parts of the bike I should buy while I am making this purchase? Clutch speed bleeders?
On certain models Honda used a different bleeder for the front brakes and clutch. Before you order Speed Bleeders for your motorcycle you need to look at the original bleeder screws and make note of the differences. If your motorcycle has the Honda # 43352-MG9-006 then you need to order SB8125LL. If your motorcycles original bleeders look like the SB8125 then you can use that part number or you can use SB8125L. The only difference between the two part numbers is the longer nipple on the SB8125L. Both will work fine.
