- Joined
- Feb 11, 2006
- Messages
- 8,058
- Location
- Jacksonville
- Bike
- GL1800 R1200RT NC700
- 2025 Miles
- 008576
I'm not sure this is the sub forum to post in as it pertains to my BMW R1200RT. I'm sure mods will move it to where it needs to be,
I bought a Feniex T3 strobe light head to augment the brake lighting on the RT. My ST and NC have a similar strobe head installed in the brake light circuit. The BMW has a Canbus computer controlled electrical system that requires a different hook up. The single filament brake light bulbs double as running lights - as running lights the computer sends the bulbs about 30% power or about 3.7 volts and they glow appropriately as running lights. When the brakes are applied the computer sends the full 12.6 to 13.6 volts to the bulbs and they glow at 100%. When I installed the Feniex in the brake light circuit the strobe flashed constantly at the power of the bulb which is 30% all the time and then goes to 100% when the brake is applied.
I'm thinking there must be a way to wire into the brake lights and still prevent the strobe from coming on until the brakes are applied. Can I install a device like a diode or resistor that stops 3.7 volts from passing through the wire to the Feniex but allows 12+ volts to flow when the brakes are applied. I thought about using the brake light to trigger a relay but I read that automotive-type 30 amp relays will remain energized with as little as 1 or 2 volts so would not release when the brakes are released.
