I installed a set of RT .934 kg/mm springs on my 2006 ST 1300 PA about 7 years ago. I noticed right off that it sat higher and leaned over quite a bit more on the side stand. I put on another 30K , and seeing how i have five bikes to ride i didn't give it much thought till now. Its winter here in Canada, i have nothing but time. I'm going to strip the bike down and do all the fluids.
I figured as long as I'm doing that, i might as well take the forks off and, put in new seals and sliders, and fix these forks.
I measured my sag today and its 27mm. I'm not an real aggressive rider, so figure that i should be around the 35 mm mark. I did make note that when I originally put the RT springs in that I used a level of oil of 130mm. Don't know where I got that as the service man recommends 62mm.
So this is where i need the assist.
1. What is the proper oil level for the RT springs.
2. To get the right sag, do i just shave off 8mm from the spring collar/spacer?
Thanks..........from cold Cochrane Alberta
