radar bluetooth dongle Sena?
Norman, OK
ST1300 '08
does anyone know if the Bel radar detectors can be blue-toothed via dongle to the Sena headset? I am presently using the mini cable from Bel to headset - it works.. but is cumbersome. other blue-tooth/dongle routing option (?) via GPS unit?
thanks -
Tom Mac 04a
LI , New York
04 ST1300a
8347
If it has an ear jack, YES it can be BT to the Sena headset...I use a BT by Jabra A120 for my gps.
A couple of things to remember ... You have 3 BT imputs to the Sena. 1-A2DP for stereo , 1- HST heaset for usu phone, 1- intercom (tho it holds 3 adresses)(( does the lastest update do group?))
You can't use the Sena input jack AND the A2DP at the same time... plug into the jack and the a2dp bt quits
So, if it has a ear jack, get a cheap BT dongle and it should work fine
Norman, OK
ST1300 '08
ordered a dongle.. so, I pair it with the phone button, not the jog dial, right?? thanks again -
Tom Mac 04a
LI , New York
04 ST1300a
8347
It should pair to the A2DP if its an A2DP dongle... only problem you may have is it's stereo and if the radar is mono, you may only hear it in one ear. Might need a stereo to mono adapter for both ears... better yet make a short extension plug ( m to f , stereo to mono ) so there's no wear tear on your radar jack if unplugging all the time.
Only testing will tell
OR as a thought (haven't tested it) you could make your extension having one mono unit (radr) on the left ear and another mono unit (gps) on the right! :)
Norman, OK
ST1300 '08
when I've used it wired to the SENA, I've used a stereo-to-mono plug. I suppose that creates a bit of weight on the BEL jack.. I intend to use that same adaptor when the dongle arrives. I suppose I could put some black tape on it or something to help alleviate stress on the output. thanks again -
drrod
Calgary, Alberta
'04 ST1300
8313
If you use something like the Bekin Rockstar
http://www.amazon.com/Belkin-Rockstar-Multi-Headphone-Splitter/dp/B00475K64E
You can hook up all your stuff to it including the bluetooth dongle. No strain or stress on any of the jacks. I use this and have it in my RF glovebox. I leave the GPS/MP3/RD/BT dongle hooked up all the time to it. Lots of volume with my V1 detector, even though it is only in one ear. GPS/MP3 are stereo and great volume. Phone - not so sure since I don't bother hooking my phone up.
I wear foam earplugs and can hear just fine up to speeds where you should be paying close attention to the road anyway.
Rod
Norman, OK
ST1300 '08
excellent drrod. I'll get one of those too.. cheap enough to be worth fooling with. thanks !
