2002 ABS.
Just rebuilt the forks; have not done it for awhile. New seals, bush guide, bush slider, new bottom bolt with washer. Did progressive springs last time.
Left side has the damper rod.
Put it all together, added oil to 6.9", got the rod/cap connection done and screwed in the cap. Almost no problems.
Until I picked it up and set it aside. Has a distinct rattle. Sounds like the spring rattling; but it is obviously in some compression - the normal amount as exhibited by trying to thread the cap on. WTH?
Do not remember this from when I took it apart a couple weeks ago. All the parts in the pic are installed, in the correct order.
Other than the left side using a bit less oil than the right side (I assume due to the displacement of oil by the damper rod) , no problems going together.
Any ideas?
Any ideas?
