Purchase an old style metal oiler can with a ridged spout at the hardware store, along with some 3/16 x 5/16 dia. clear tubing.
cut a section about 6 inches long and attach it to the spout of the oiler can. Fill up the can with Dot 4 brake fluid.
Attach the clear tubing to the bleeder nipples (in proper sequence) and open the master cylinder, making sure its only about half way full.
Crack the bleeder open just enough that when you pull the trigger on the oil can, it moves the fluid into the bleeder.
Watch for bubbles up top, and make sure you don't over fill it. Go slowly, and have someone keep an eye on the master cylinder level.
This is a reverse bleed, and will "push" the air upward in a natural direction into the master cylinder housing.
Once you've done this and no more bubbles appear, do your normal bleed.
I would suggest using a motion pro hydraulic bleeder (check valve) instead of a mity vac. It will be easier and have less chance of sucking more air into the system.
You can also use a syringe, however, with that, there is a change it will blow off the nipple and get brake fluid everywhere.
I find the oil can much easier and safer.
Let us know what happens.
