Rear Caliper 14mm Bolt Torque?
Wheatland, WY
I accidentally loosened the 14mm bolt on my rear brake caliper. Does anyone know the torque on this bolt. The brake removal instructions say the pad pin torque is 13 ft/lbs, but it does not give the torque for the bigger caliper bolt at the front of the rear caliper.
The rear brake caliper stopper pin bolt has a torque spec of 51 lb/ft.
Ray
Ray
Thanks, I know that torque as well. However the actual rear caliper has a bolt right in front of the brake hose. It is the front caliper bolt of the rear brake caliper assembly. I need to know the torque for this caliper bolt? I'm going with synthetic caliper bolt grease, blue lock tite and 20 ft lbs if I don't get a response.
If you're talking about the bolt that attaches the caliper to the caliper bracket, that's also 51 ft-lbs plus medium thread lock.
--Mark
