Hi I’m wanting to replace the rear shock bushes on a 92 pan , I’ve found bushes for a 95 onward but am unsure if they are the same ?
Also will any shocks off a newer model pan / or any other Honda fit ?
Thanks
I checked the parts fiche for a '91 and '97 and they use the same upper bushing, so I suspect all of them are the same.
I don't know if the shocks are the same for all years. I suspect they might be, since very little changed over the years, but I don't want to say for sure.
Hagon used to claim - might still do - that theirs matched the ABS model. However, if their test model was an ABS, what do you call it? I'm not convinced there is any difference between the ABS and STandard versions.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
