Sorry to ask what perhaps to some is a basic question, but from reading a thread on the other ST1300 forum I’m left a little puzzled.
In an attempt to achieve ‘correct’ sag whilst I’m on the bike, I did the following.
Put the bike on it’s centre stand.
Removed the right pannier.
Taped a piece of string to the axle bolt of the drive shaft.
Put a piece of masking tape on the painted plastic panel vertically above the axle bolt at the drive shaft.
Put a level line on the masking tape.
Offered the string taughtly and marked a point on the string corresponding to the marker on the masking tape.
Measured and placed two marks lower down the string. One mark at 30mm and the other at 36mm from the first and original mark.
Put my gear on and a 2.5 kg weight in a rucksack on my back. This to restore the weight lost from the removed pannier.
Sat on the bike and with a pole and a wall, balanced all my weight on the bike.
My wife then offered up the string and bingo, the 30mm deflection marker was lining up with the mark on the masking tape.
Now I didn’t expect this, as all I keep reading is how undersprung the shock is. I’m about 195 pounds fully geared. The shock preload is just about in the middle of its range of available clicks.
The bike is currently very low on fuel. So I suppose another 26 kilos could be attributed to the equation in a manner.
Have I done something wrong?
