Recommend a fuseblock?
mello dude
Dayton Ohio
I'm looking to clean up some accessory wiring and goto mbe a 6 gang fuse block.
Seems like there is 50 choices. What have you used successfully?
Thxz
I tried something different on my Africa Twin - It is called a Healtech Thunderbox. It is not too expensive and internally protects without fuses. It can operated automatically by sensing if your engine is running or can be triggered with a switched 12v connection.
Depending on your needs, you may want to have room for later. I have a 6 terminal, using 5 plus the bikes extras. If I was doing it again, post #3, eastern beaver.
  1. USB
  2. Phone
  3. GPS
  4. Courtesy Lights
  5. DIN Socket
  6. Top Box Power
  7. Heated Grips
  8. Heated Seat (unused)
  9. Heated Gear
  10. Lighting Circuit 1
  11. Lighting Circuit 2
  12. Lighting Circuit 3 (unused)
  13. Meep Meep Horn :rolleyes:
I've put 3 PC8s (easter beaver) on my bikes, the last was a PC8R. They make good stuff. I did use a BlueSea fusebox on a Guzzi because it had more than 8 circuits.
I do not like the Thunderbox by Healtech for several reasons. It offers only one or two circuits (depends on the model) and they are protected at, iirc 20 amps. This means that if you use lighter wire - say 18awg for something, it is not properly protected since the 'fuse' or more accurately, circuit breaker ahead of the wire is rated at 20 amps. If you 'blow' the fuse and have to reset it, Healtech says to remove the wire from the battery for a few seconds and replace it. I think this is cumbersome and not user friendly. The thunderbox is electronically switched on when you turn on the ignition with no additional wiring - a benefit. It is also a very small parasitic load - another negative. My last thought is the physical layout of the device is such that it leans toward spaghetti wiring - a tangled mess.
16 amps. I agree with you that this is on the low side- I don't think that this is even high enough to run two Fiamm horns. I prefer to have the option of a higher capacity circuit if I want it. It also only gives you one or two additional circuits, depending on the version, which is not very much. If I am going to go to all of the trouble of connecting up a secondary fuse block I certainly am going to choose a fuse block that offers more circuits than that.
It allows an over-current for a maximum of .002 seconds before disabling the circuit, which is a good feature. If it does disable the circuit due to an excessive current draw it will reset itself with no outside intervention and restore power if the excessive draw is no longer present. It will attempt this three times before it permanently disables the circuit requiring the reset procedure that you outlined. Rather cool tech I suppose but I agree with you again, I'm not convinced that I wouldn't prefer a standard fuse.
It draws 1 M.A. in standby mode. If not used it remains in this mode for 24 hours after which it turns itself off completely eliminating the drain, so not really a concern.
To Mello Dude:
Below are some of things that I discovered that I needed to decide about in order to determine what features I needed in a fuse block. Once you have decided what you need/want you can go about eliminating the fuse blocks that do not offer those features.
- How many additional circuits do you want? You mentioned 6. The greater the number of circuits the fewer the choices there are.
- Do you want it to have an integrated switching relay to power on or do you prefer to have a seperate switching relay that you wire in yourself?
- Do you want some of the circuits to be always on instead of being switched? Some offer this option for the purpose of connecting a battery tender, or a phone charger as an example.
- Do you want to be able to easily alternate some of the circuits between always on and switched? Some offer this feature. I'm not sure of its usefulness as I don't know why I would want to switch the same circuit back and forth between always on and switched but it is an option that is available.
- Do you want the fuse box to have both power and ground feeds? Many only offer power feeds and the ground circuit is through the motorcycles' existing ground circuit. Others have dedicated ground connections at the fuse box. This means that every accessory has to have two wires run to it from the fuse block, one for 12V+ and one for 12V-. The ST1300's electrical system is known to have a ground system that does not have much excess unused capacity available, so running dedicated ground circuits directly back to the fuse block is not a foolish idea.
- Do you want it to be waterproof? i.e. Actually rated waterproof as opposed to water resistant. Some are, most are not. I have never read of a fuseblock failure related to moisture, so I don't consider this a deciding factor.
If you can decide on which features are absolute must haves you can then narrow down your choices by eliminating those that do not offer the features that you want.
I have had the Thunderbox now for about three years. It has been flawless - I have not had any parasitic load noticeable at all but I do not operate it in automatic mode and use a 12v trigger wire to operate it. These are very small and I have two of them piggy backed and they are still much more compact than a typical fuseblock setup. - the wiring is so much cleaner using the Thunderbox and for my Africa twin it is very waterproof as it is fully sealed, no terminal strips etc. I just run the wiring under the tank from the Thunderbox up to a distribution point near the steering head and branch out from a waterproof sealed connection at that point to all my accessories. Super clean and simple. It removes so much wiring mess under the seat and so many wires having to route to various points. I used a PC8 fuse distribution block before and I can say that this is a much cleaner way to go.
I used a Fuzeblock on my ST and then transferred it to my Goldwing. It was designed and made by a former ST owner who has passed away. It can be used as an always hot or on and off with the key. It just depends on what terminal you put the fuse in. It has worked great for the past 20 years of use.
Depending on how many accessories you have I have used the OEM fuse block for several things, my 04 doesn't have ABS so there are a bunch of blank spots. Not sure if yours has any spares
I’ve used the Centech AP-1 and AP-2 fuse blocks on a Honda NC700 and Goldwing. It's compact and easy to locate in tight spaces.
You can go overboard with a 12 slot Blue Sea, like I put in my sidecar rig.
Or you can go minimal with a 5 slot Centech.
@mello dude PM me your address, and I’ll send you the centech.
