John OoSTerhuis
Life Is Good!
Would someone please post an image of the end of an ST1100 left side (#2 cylinder) camshaft that shows the index line mark and punch mark used in timing belt, valve shim R&R, and camshaft install procedures.
Anyone have a good picture, or have a left cam on the bench or valve cover currently off? Many thanks in advance!
I’d like to confirm the existence of the punch marks mentioned in the Honda Service Manual (p.8-13) and discussed in these threads:
www.st-owners.com
www.st-owners.com
Regards, John
Setting the camshafts after a full top end strip down | ST1100 Related
Hi have searched and searched for a definitive article relating to setting up the camshafts after a full top end strip-down, specifically the left hand cylinder head cams and can't find an easy answer. Have fitted new refurbished water pump, new tensioner and idler, refurbed heads, here is my...
Cam timing questions. Is the Honda Manual Correct? | ST1100 Related
Ok so I have the engine out. I replaced the timing belt night before and today went through all the valve adjustments and shims. In doing this I removed all the cams. Not a big deal right? Well I started putting it all back together per the service manual. When I went to do the left side, wham...
Regards, John
