What is everyone using for valve stems? The standard straight ones aren't too friendly.
Ariete valve stems.
Ariete valve stems.
I don't live in Europe but since changing to right angle stems 8 years ago I don't think I have ever encountered an inflater where the OEM rubber ones had any advantage.
Basically we're confronted with 3 different types of inflate adaptors:I don't live in Europe but since changing to right angle stems 8 years ago I don't think I have ever encountered an inflater where the OEM rubber ones had any advantage.
I have not noticed any corrosion or cracking. Anodized aluminum is very durable but all metals are subject to it at some point. If the O ring begins to leak air from deterioration it will not be a sudden failure. I check the tire pressure weekly so if I notice a slow leak I investigate. So far any slow leaks have been foreign objects in the tire. I haven't noticed rocks knocking the valve loose yet but I generally ride on hard surfaces.Angled valve stems:
Is the aluminium cast not prone to corrosion/cracking at some time?
How long will the O-ring sealing towards the bed hold up in there?
How about rocks knocking when getting caught in another roadwork to cross?
I get my rubber stems replaced at every tire change and trust them a lot.
The only metal stems I've on a vehicle are on the wheels of the panel van... their very short (only stick out the length of the dust-cap thread), and pretty thick (IIRC a 13mm nut holding them on the bed)I have not noticed any corrosion or cracking. Anodized aluminum is very durable but all metals are subject to it at some point.
I am using some valve stems sold thru BikeMaster.com. (http://www.bikemaster.com/valve_stems.html) our local Honda dealer had them in stock
I had them installed at the last tire rotation. Solid aircraft aluminum. Much nicer to check the air pressure with.
Ken
Where can I get a set. Kurvy girl is sold out and item discontinueddiscontinuedAluminum billet 83 degree Ariete stems.
Thanks, I just ordered a set from themI found a set on amazon.
Sent from my C811 4G using Tapatalk
