Pan has been out on drive for sometime and,though covered,the rear brake has seized.I obviously need to unseize it but don't want to damage it in the process.Any ideas beyond WD40?
Definitely leave that WD40 can in the house...Pan has been out on drive for sometime and,though covered,the rear brake has seized.I obviously need to unseize it but don't want to damage it in the process.
Thanks this helpsI'm not familiar with the 1100 but I believe you do not have the Secondary Master Cylinder. It would help if you post the year and if it is ABS or not. Not knowing, I'd open the rear caliper bleed nipples to relieve pressure. If the wheel unlocks, then you have a return port blocked in the brake system. If it is still locked, then the caliper is frozen on its pins (it should slide side to side as the pads wear). In this case you will need to remove the rear caliper, clean and lube the pins and probably clean the pistons as well. Corrosion does not heal by itself.
It is a good idea to keep WD40 away from the brake caliper!
Beats scratches and possible other damage whilst attempting to pry a screwdriver or tire iron between rotor and pad...... Walmart not so much ($39).
