I find it more useful to put the clearance value and shim size on the same page next to each other, makes it easier to visualize. No need to convert the shim size to inches, just remember every shim size is equal to 0.001" and do the adjustment on the page with the before/after shim sizes listed.
For example:
looking at that I can decide at a glance if I want to leave it at .007 or adjust it one step to 1.90 to put it in the center of the range. If I happen to have another 1.90 shim available as a spare or from another cylinder then for sure I'll adjust it, otherwise I may just leave it where it is because its still in spec. Seeing all the new sizes needed on the page helps visualize where you can swap shims around rather than buy new ones using circles and arrows to show what's being swapped where.
