Side stand lamp is on all the time
Poole
Hi all my orange side stand lamp is on all the time ? It starts ect all fine , any ideas what might be causing it ? I’d have thought if the switch was faulty the bike would cut out when I put it into gear?
Thanks
1st thing to do is look at the switch, is it plugged in, wires broken? Unplug switch is light still on, jump the connector is light still on? We are looking for a change in the light and testing it's circuit at the same time.
from the schematic it looks like there's 12v direct to the light, and the sidestand switch provides the ground when its down. Then when you put it up the ground path is broken for the light, and another ground path is created for a wire from the ECU. If that ECU wire ground is broken, then it won't start. So what it sounds like is you're providing the ground to the ECU well enough, but there's something amiss in the switch or wiring that continues to ground the wire from the indicator bulb regardless of sidestand position. check the switch and wires for clues. The wire from the bulb is the yellow/black one, the ground wire is the green one, and the ECU wire is green/white.
I don't see anything in the schematic that indicates the rectifier would be involved, that's more related to the neutral light.
