Is it normal for the st1300 to lean at such a big angle. I am short and having trouble getting my st up.
Pretty much yeah. You might check the stand to see if it's bent or if the clevis end is splayed open allowing for a greater lean angle. You might consider a bolt-on foot pad used to keep the side stand from sinking in soft earth or gravel. Some of them are probably add 1/2" or more which would make a noticeable difference. This can work against you though. Situational awareness when parking your bike is a big help. So are highly tuned quads.Is it normal for the st1300 to lean at such a big angle.
I am 5ft 6in 29in inseamI've never heard of anyone cutting down or otherwise altering their side stand. If your preload is cranked up, that raises the rear of the bike. I think the real problem is the ST's weight. There were times when I could barely get the bike up off the sidestand (i'm 5'7 and weigh less than 1/5 what my bike weighed). This was especially a problem on highly crowned roads or when parking in a lot with a pronounced grade.
I would have to say, yes, this is normal. I did make a shoe for my ST so that it would not sink into hot asphalt or dirt, but found that the 3/8" thickness made the bike sit too upright in some situations. I remember one where I could not get off the bike, I had to ask a friend to hold the bike while I got off, then the two of us pulled it backward out of the sloped parking space so that I could turn it around.
I have not checked to see if it's bent but will later today. As far as quads go, I have a lot of work to do on them. Lost a lot of the strength in the left one after my left hip replacement. I think I will cut a board and attach a string to it to straighten up ST a little bit.Pretty much yeah. You might check the stand to see if it's bent or if the clevis end is splayed open allowing for a greater lean angle. You might consider a bolt-on foot pad used to keep the side stand from sinking in soft earth or gravel. Some of them are probably add 1/2" or more which would make a noticeable difference. This can work against you though. Situational awareness when parking your bike is a big help. So are highly tuned quads.
I had all fluids changed but never thought about the preload fluid and it is definitely low. Would that make any difference? Is there any easy way to check if it has an aftermarket shock or spring. Thank you for responding to my questions.+1 on the side stand mounting bracket being bent, or, someone may have put an aftermarket rear shock or spring on it making it taller etc.
As far as raising the bike up after your sitting on it, try turning your bars to the right, this will help you raise the bike.
Same inseam here. But as I got older, I got shorter and the ST became too much for me to horse around with the engine off, either in parking lots or at home in my driveway. I mounted my bike by standing on the left side peg, then sort of dropped onto the seat to settle (and lower) the suspension at the rear. This helped somewhat. I also had a couple of 'feet' for the side stand (one was a full 3/4" (maybe 7/8") with string attached that I put under the sidestand when parking on sloped grass - for camping. I found it nearly impossible to get the bike upright with full panniers and a duffle on the pillion without that wooden 'puck'. I also had an electrical box cover plate and a telescoping magnetic pickup tool for asphalt parking lots. Easier than kicking the plate under the stand. And yes, all had fluorescent string attached.I am 5ft 6in 29in inseam
Will have to check AmazonST Viagra will help......![]()
A working preload will RAISE the rear of the bike if you add preload to the spring. Preload will level or return a heavily laden bike to the stock attitude, since raising or lowering the rear affects the trail of the forks and thus the handling. Adding preload will exacerbate your problem. To determine the spring rate of your shock, check the sag. With rider aboard in full riding gear (with your regular load in the panniers) sag should be in the neighborhood of 1/3 of the total travel (I forget what it should be). Preload should be backed all the way off when checking sag. @dduelin can probably help you with this.I had all fluids changed but never thought about the preload fluid and it is definitely low. Would that make any difference? Is there any easy way to check if it has an aftermarket shock or spring. Thank you for responding to my questions.
Frank
Cheaper at Canadian pharmacies.Will have to check Amazon
I am 67 and probably shrinking also and definitely not as strong as I use to be. I also mount using left peg. It's so much easier.Same inseam here. But as I got older, I got shorter and the ST became too much for me to horse around with the engine off, either in parking lots or at home in my driveway. I mounted my bike by standing on the left side peg, then sort of dropped onto the seat to settle (and lower) the suspension at the rear. This helped somewhat. I also had a couple of 'feet' for the side stand (one was a full 3'4" (maybe 7'8") with string attached that I put under the sidestand when parking on sloped grass - for camping. I found it nearly impossible to get the bike upright with full panniers and a duffle on the pillion without that wooden 'puck'. I also had an electrical box cover plate and a telescoping magnetic pickup tool for asphalt parking lots. Easier than kicking the plate under the stand. And yes, all had fluorescent string attached.
Did anyone else read this and immediately picture George Costanza Yelling" I WAS IN THE POOL!!!"I am 67 and probably shrinking ...
Was no print , I just eyeball it as I make it in my garage , wait a bit , I will take another photo straight down on it , you can compare sizes to the foot on your ST.Can you send a print of this to be produced again? #tournut
