What gauge wire is used the the front turn signals of a ST1300
Measuring smaller wire sizes - especially stranded wire is difficult. I've tried it and you have to cut the insulation w/ a stripper, pull it away from the main piece of wire (exposing a short section of the bare copper, and then measure it with calipers. It's difficult because you can squeeze the stranded wire w/ the calipers getting the wrong reading, stripping the insulation cleanly is not easy, and I've discovered there seems to be some leeway in what the dimensions of the wire are supposed to be and what the calipers tell you.Why not open it up and measure the wiring (?)
