Hi Folks,
I installed The ST2 Smart Brake Module today on my ‘94 ST1100
it uses an accelerometer to sense deceleration and when installed, it will put the brake lights on before you activate the front or rear brake lever/pedal. It was simple to install but if your electrical knowledge is poor like me, you must make sure you have a wiring diagram of your model ST1100 in order to identify the correct wires. Mine is an “R” and my Haynes Manual has 7 different wiring diagrams. Though all similar, make sure that you have the proper diagram for your bike.
The enclosed instructions are clear, the hardware is good, and it’s a fairly simple install once you find the proper wires.
The Unit has to be installed so that it is level. You can decide where to mount it. I selected the area behind the seat, and behind where the tool kit and Owners manual is located:
To access the area behind the plastic in the compartment, you have to pry the two sides inwards and fold them together. The back plastic will then tilt forward:
With access to this compartment, you can find the proper wires and use the ingenious wire connectors that are supplied with the kit. Some people will probably want to make solder connections, but the supplied connectors seem to make solid connections.
My choice for mounting location of the Module was the underside of the steel frame cross member at the top of the compartment. I used heavy duty outdoor double sided tape to mount it and further secured it with the supplied nylon “zip” ties.
I had to “notch” out the corner of the plastic panel to close it, seal everything up, and put it back together.
And voilá, job complete. A quick test ride on the street with my wife watching and she confirmed that it works as advertised.
In my opinion, this will enhance enhance safety for me and is worth every penny. Check it out at https://safer-turn.com/
They make a “Smart Turn System“ self-cancelling module as well. I bought one and I will be installing it on my ST1100 and will post another thread on it’s installation as well. Furthermore, I will be installing each of these units on my ‘07 ST1300 when I get home.
Safe riding everyone.
Cheers,
Bill
Cheers,
Bill
