Ever since I bought my 1300 I've noticed a bit of pad/rotor noise when the brakes aren't applied. Just enough to hear it when the helmet shield is up sometimes, otherwise it's barely there.
I recently removed the rear caliper for a tire change and it was very dry and crusty so I figured the fronts might also need a little lube and that maybe the pads were sticking or even the pistons might be a little corroded. Got the left side taken off and notice this lovely scene:
Clearly the bracket is rubbing on the rotor. I'm a bit surprised the rotor isn't worse off, but I guess it's only cutting into aluminum so maybe not. Anyways, after a quick check to make sure nothing was mounted wrong or bent, I figured it must be the wheel. Sure as hell, after looking nice and close, the front wheel is definitely misaligned just by eyeing it from the fender:
At least somewhat my fault for also not noticing... I'm assuming whoever did the front tire last (wasn't me...) put the spacers on the opposite sides they're supposed to be. I probably couldn't hear it very well because it was very slowly eating away at the bracket.
Oh well, going to swap the spacers around tomorrow and lube everything up real nice and see how it runs. No other damage that I could sense, wheel bearings are great and the calipers/pads are still in good shape. Rotor isn't even too worse for wear, the brakes work great to be honest, so luckily that won't need to be replaced.
