Uncle Phil
Okay ST Sleuths, here are the sequence of events so far -
1. We removed the carbs to clean the idle jets that were stopped up (bike had been sitting a while before I got it). Upon reinstallation, the bike seemed to have a vacuum leak. We thought that it might be the lower clamps on the carb boots. I decided I would pull them later and check it out.
2. Saturday, I pulled the carbs and found the lower boot clamps to be tight. Since I have 2 extra sets of carbs, I picked one, removed the bowl covers, verified that I could blow through the idle jets, button it up and installed them on the bike. The bike ran fine so I decided to take it to get some fuel and for a test run before I buttoned it up.
3. Put on my gear, got to the end of the driveway to pull out uphill, and the bike acted like it was running out of fuel. If I blipped the throttle it would keep running. I headed down the hill and road a few miles to fuel it up. Then I ran several miles up and down the interstate to check it out. Problem seemed to be getting worse.
4. Bypassed the vacuum fuel valve, thinking it might be the problem. No improvement at all.
5. Pulled new carbs off, installed the idle jets from the new carbs into the original carbs, reinstalled original carbs on bike. The problem got worse. The bike now only will hit if I continously turn the starter over and will not run.
I plan on checking to see if the fuel filter could be clogged and pulling a spark plug to see if it is wet or what color it is.
Sooooooo, any suggestions at this point - besides putting it on a trailer and carrying it to a STealer to get ripped?
