gar
Looking for some advice. I have a 1991 st1100 60k miles, and as expected is starting to show some basic surface rust on the swingarm. I can see that there is an ever present drop of water on the underside of the swingarm in the place that most of them rust through (if you turn it upside down, the bottom right of the 'u' shape of the swingarm). I have poked around this bit and there doesn't appear to be a hole so I'm guessing there are very small ones appearing through the metal??? I know water gathers there if it has been ridden in the wet but there is still a drop there days after the bike has dried in the garage so I'm thinking it has got into the inner section of the tubular steel.
Anyway I'm thinking of refurbishing the swingarm this winter to try and avoid the ?250 cost of a second hand one and proactively guard against any major corrosion. I'm thinking of sand blasting it, filling in all the gathering points and small nooks which Honda have left in its design, then galvanising it and painting it over. Is this job as a whole recommended and if yes is the galvanising a good idea or would a lick of zinc paint do the trick?
What else would you think is worth doing while the arm is off - I've seen guys mock up mudguard extensions to try and protect the swingarm better, and also do the swingarm bearings.
Any thoughts from the experienced owners really welcomed.
