RJWWL
Back on the week of Thanksgiving I went to ride my ST13 to work...1st thing i noticed when I turned to key was I was missing the distinct sound of the fuel pump. I had all lights and battery just came of the tender. I turned the key on and off several times and switch the off/run switch back and forth a couple times...said a few choice words then climbed on my other bike. As soon as I got home from work I went to check it out...and found that everything seemed to be just fine...what the heck? So I tried again the next morning and everything seemed fine so off I went...I got about 3 miles from the house when she fell on her nose. I pulled over and rocked the off/run switch a couple times (I was on the side of the interstate so I couldn?t hear anything) hit the start button and bike came back to life and for the most part has been fine since. About 2 weeks ago I went to start the bike and once again I was missing the distinctive sound of the fuel pump...this time is never came back. I checked the fuse then loaded the bike on the trailer to take to the dealership. 2 days later, dealer calls and say bad fuel pump. $875 and he gave me a 10% discount. He continued by saying that there is power to the pump and the pump does not work. Said that they would have to completely remove the bottom fuel tank and the rear fender has to be removed to get the tank out and they will have to order it. This was a Saturday and I was out of town and they were closed on Sunday and Monday so it gave me a couple days to think about it...I just didn't believe that it was a bad fuel pump. I picked the bike up and brought it home and started tinkering with it...I found the harness that the pump plugs into with 3 wires. 1 wire pretty obvious is the ground, while the center seems to be directly related to fuel gauge and the 3rd wire to the pump. When checked with a volt meter I found that there is no power to the pump but there is for the fuel gauge. I shaved a little insulation back and hotwired the fuel pump to the battery and it comes to life (pump not the bike) At this point I?m a little irritated with my dealership as it does not appear that they performed a thorough diagnosis and I cannot see a reason why you would have to remove the tank to remove the pump assembly. Thought I would post my story here to see what feedback I might get before I start taking things apart. I live in the rural areas of Kansas and inherently have mice in the garage so I?m hoping for something as simple as a chewed up wire but I?m thinking that I may have to remove some large components (fuel tanks, Air breather, etc.) so I can see more of the wire harness - Any insight?
I?m also wondering what components are between the fuse and the pump?I?m thinking there must be a pressure switch of some type and am also wondering which model of service manual would be recommended and where would be the place to acquire it?
