ST1300 Top Box Harness Installation Instructions?
Serbia
ST1300 (2004)
08E75-MCS-600
STOP LIGHT HARNESS
Does anybody have printed version of Installation Instructions to post here and "how to..."? Detailed photos maybe?
Thx
Here's a thread on the top box with some pics of the wiring install, what I've found so far on the site...
Thanks a lot, but I'm still searching for schematic of the OEM harness and all the connectors where are they plugged in, with pictures if possible...how Honda did it.
I believe the instructions say to cut the brake harness by the bulb (green wire(ground) and green/yellow wires(+12v)) and crimp in the harness Y connector that runs to the top box.
To my knowledge there's no "plug and play" place to connect it into the bike's existing wiring.
I was wrong, there is a location as per @STRider 's comments below :)
Forgive me for correcting you @Obo there is a place that allows for a plug'n'play connection.
I wired the brake light of my Givi topbox to the brake light connector close to the rear master cylinder. There's a two terminal connector in that location, actually just behind and below the right cylinder bank, accessed behind the right upper cowl. It uses the same Hitachi style connectors I see in your photos and that of the accessory harness. See photos of my bike below.
From the photo posted by @dejankiss it appear to use these same connectors I used, but I can't be certain the wiring is the same, though I believe so. Never having seen this harness before this thread, I think I replicated it independently on my own. I tapped into the green/yellow wire in the OEM bike harness (black in my homemade wiring) and that appears to be the same on the OEM harness.
I believe their inclusion of the terminals and two-wire connectors suggest that, yeah, Honda may direct you to cut into the the brake light wiring as you show in your photos, but you don't have to. Even if you need to extend those wires from the kit to reach the rear of the bike where the box is located you can avoid cutting into the factory wiring harness on the bike.
