Starter valves sticking
Calgary
2008 ST1300
Ran into a problem where the bike suddenly has an extremely high idle (4000RPM), pulled the air cleaner housing and was checking the throttle body (I assumed the throttle plates were being stuck partially open after installing the cruise control, note the bike WAS idling just fine after the cruise was installed).
I start moving the starter valves by hand and I notice that the valves for cylinders 1 & 2 don't move very smoothly and they kind of stick a bit. I suspect that what is causing my high idle is that the starter valve got stuck open and as the engine warmed up the idle kept climbing until I shut the engine off (the idle was very high upon restarting the engine).
The idle is back to normal at the moment but I am trying to fix this issue so I don't end up stranded on the road as it is extremely unsafe to ride with a 4000RPM idle (plus damaging to other components). So my question is... has anyone had luck in pulling, cleaning and lubricating these valves? What kind of lubrication would work here? Is there a way to remove the valves without removing the throttle bodies?
Warning….do NOT clean the black coated strip on the butterflies, brake clean, carb cleaner, and many chemicals will remove this coating.
If removed, your TB will need to be replaced!
What you’re describing can be one of two things, the little pistons that can be seen through the two small snakebite looking holes, are dirty, and sticking (common).
These can be freed up with a couple drops of mmo while the bike is running.
Secondly, and probably your issue, you have fouled either the linkage rod while installing your cruise control, or the IDLE WAX VALVE LINKAGE, etc.
The idle wax valve rod is threaded DO NOT try to adjust the nut, or change the factory setting or you will cause more issues, inspect the threaded rod where it goes through the black plastic ferral, if it’s dirty, dry, or the threads are snagged on the edge of the hole, your idle will go wild until it vibrates and frees its self.
Make sure the black plastic barrel is free to rotate and move, and the threaded rod is not getting caught.
Lastly it could be air leaks from your cruise control, but I suspect it’s the rod snagged.
Thanks for the info! First question: What does that black coated strip do?
I'll check both linkage rods (starter valve and throttle butterfly valves), I haven't touched the wax valve linkage but that might be a good spot to check to make sure its clean as the lower portion of the throttle body assembly is pretty dirty (I was planning on pulling the assembly next winter to clean/service and then replace the coolant and vacuum hoses) plus the idle adjustment knob/rod was stuck in place and I had to free it up with some WD40 (looked like varnish on the rod caused it to seize)
And yes, I was talking about the little pistons that can be seen through the "snakebite" holes in your picture (RIP to your crack throttle body). For applying the oil, should I put a couple of drops into each hole? Should the bike be fully warmed up first? Any reason in particular to do this while the bike is running?
The cruise control is the Rostra electronic unit with no vacuum lines, since the idle returned to normal I don't suspect a vacuum leak.
How does the wax valve linkage work? For example, when the COOLANT is cold, is the starter valve held open and as the coolant warms the wax melts (like a coolant thermostat) which allows the starter valves to close?
