Stock to LEDs?
Dave.David
Dave.David
Rider
SB California USA
05,ST1300-04VTX1800R
8938
I assume the stock flasher will not work if some of the indicator lights are changed to LED's - for example if I were to change only the fronts. Will the electronic flasher work with a mixed load (in this example, front LED's and rear incandescent)?
Yes, the timed flasher units don't care wattage of bulb or LEDs. That's why best to use timed flasher units then those load resisters which add the load that the LEDs take off your charging system.
