Switchback LED Dual Color Turn Signal Bulbs??
Boston
2000 ST1100
Hi,
Ordered the clear lens for my ST1100 and upon looking for 1157 LED kits I came across several types. The two basic types are the Sockets with external resistors which plug into your current sockets which I see in older videos and the 'new' LEDs with resistors built in for Anti Hyper Flash (quite a bit more expensive)
- Has anyone used the stand alone leds with built in resistors?
- If so, heat build up?
Thanks in advance.
Don't use resistors of any type. They only consume power and waste it as heat, which negates one of the big advantages of switching to LED bulbs which is freeing up wattage for other uses. Purchase the ones with the exterior resistors if that is convenient and the price is right, just don't use the resistors.
As stated above, switch to an electronic LED compatible flasher unit to prevent the hyper-flash.
Somewhere there’s a post with all the part numbers I used to convert my ST1100 bulbs to LED.
That will get you the part numbers for all the bulbs I’m using.
Here you go.
I see that I need the two(2) LED bulbs and the Flasher Relay. How/Where do I wire in the Relay. I seem to remember three relays on the right side of the nose fairing. Does it just directly replace that? Is the connector the same?
The flasher is not really a relay, as it has no coil, and it's in its own location.
The socket has three wires, but the flasher only uses two, not the green wire.
I just responded to your PM Jim.
I have used these switch-back bulbs for over a season now. They have worked very well for me,, and I have purchased a set for ThunderSTruck as well (not installed yet). So far,,, no resistors needed. But I will drop an electronic flasher in, once I switch the tail bulbs to LED's. Cheers,,, CAt'
