SYSTEM INSPECTION
Drain the coolant (page 6-6).
Remove the throttle body (page 5-64),
Disconnect the ECT sensor wire connector from the sensor, Ground the Green/blue terminal of the 3P connector with a jumper wire.
Turn the ignition switch to "ON" and check the coolant temperature gauge. The coolant temperature gauge should indicate "H"
If the coolant temperature gauge does not indicate "H", check the wire harness for an open or short circuit. If the wire harness is normal,
replace the combination meter (page 22-11 ). If the coolant temperature gauge indicates "H", check the ECT sensor (page 22-15).
REMOVAL
Drain the coolant (page 6-6}.
Remove the throttle body (page 5-64).
Disconnect the ECT sensor wire connector from the sensor.
Remove the ECT sensor and sealing washer from the thermostat housing.
ECT SENSOR UNIT INSPECTION
Suspend the ECT sensor in a pan of coolant {50 - 50 mixture) an electric heating element and measure the resistance through the sensor as the coolant
heats up.
• Soak the ECT sensor in coolant up to its threads with at least 40 mm (1.6 in) from the bottom of the pan to the bottom of the sensor.
• Keep the temperature constant for 3 minutes before testing. A sudden change of temperature will result in incorrect readings. Do not let the
thermometer or ECT sensor touch the pan.
ECT SENSOR
The ECT sensor terminal is shown in the illustration. Replace the sensor if it is out of specification by more than 10% at any temperature listed.
Temperature 80°C (68°F) 120°c (248°F)
Resistance 2.1- 2.6 kohm 0.65- 0.73 kohm
