Throttle Rocker on heated grips?
I installed Oxford heated grips this winter, and they work great. They have been comfortable for me on one level above the minimum setting.
I like my Throttle rocker - but I have a concern about it.
Here is where I am coming from. I have installed a number of warm floor heating elements in bathroom floors (part of my job). These are resistance type elements similar to what we put under the grips on our bikes. Most of these warm floor kits state that the wires must be embedded in thinset or lightweight mortar (for heat conduction) and specify that no rugs are to be left on the tile floor when the warm floor is operating. An engineer for one of these companies explained to me that a bathroom throw rug would trap the heat causing the wiring to run hotter in the area under the rug - and this would cause the insulation around the heating element to deteriorate and fail more quickly than if there were no rug. This would be especially so when the floor temperature sensor was not also covered by the throw rug. Since most of the sensors come with a limited length of wire, and people are most likely to use a floor mat/towel in front of the tub, the sensor is rarely covered by a rug. I advise my customers to pick up the rug after use.
I am concerned that using the Throttle rocker will similarly trap the heat on the grip and result in early failure.
Has anyone run a Rocker or Cbuster for any length of time with no problems on heated grips?
I have had Hondaline grips and crampbusters, one on each grip for 2 years with no problems whatsoever.
Settings on the grips are 1 to 4.
I have only used number 1 & 2 settings.
I'm not sure why Honda put settings 3 and 4 on there as they are unbearably hot.
I just got a throttle rocker over the Honda heated grips,I'm sure it will help on long journeys but I can't get used to it,feels very in the way.
I don;t see how a Throttle Rocker could trrap any more heat the your hand wrapped in a nice insulating glove could.
So I would say no worries.
I keep Grip Buddies on my heated grips year round.
I'll second that thought; I've only used 1 & 2 on my Oxford grips - but so far I've only worn thin deerskin gloves. Nothing insulated yet.
Thanks to the other responders. I'll go ahead and use the Rocker as a wrist rest. When positioned properly, I have found it tends to keep my wrist straight, and since I have had trouble w/ carpal tunnel this is important on longer rides. And, worst case, I may end up replacing the heated grips a year early. No big deal.
...An engineer for one of these companies explained to me that a bathroom throw rug would trap the heat causing the wiring to run hotter in the area under the rug - and this would cause the insulation around the heating element to deteriorate and fail more quickly than if there were no rug.
That concern, and the rationale behind it, makes sense for a bathroom floor heat installation which is installed in a home where the ambient temperature never goes below about 20?C (70? American), and there is zero airflow over the heated floor and/or the throw rug on top of the heated floor.
But, on our motorcycles, we only use the heated grips when it is cold out (temperatures well below 20?C), and the handlebars stick out into the cold air stream passing all around us. My take on it is that when it is cold as a witch's teat outside, and our fingers are freezing, it ain't too likely that the heated handgrip is going to overheat underneath the throttle rocker. :)
I've had Honda heated handgrips and a ThrottleRocker installed together on my ST1100 for over 10 years and 160,000 km, and both still work just fine.
Michael
