Tire Mileage Report - Michelin PR2 - front
Union Beach, NJ
7746
I've found they do make a bit of noise in a curve when low on air. Otherwise, they are as quiet as anything else.
Tom
Anthem, Arizona
In Phoenix Arizona we have rubberized asphalt, I recently got 20,000 miles on a rear PR2 that was not yet down to the wear bars, and got 32,000 miles on the front pr2. I just put on a new front PR3 and am very excited to see how it holds up, despite some early negative reports. I have noticed a significant mileage difference when I keep the air pressure at 42 psi. I could not be happier with a tire. In Los Angeles, on a different bike and tires, I could only expect 5000 miles. The traction dry and wet with the PR2's always blew my mind, and I expect the same or better from the PR3s.
Rindge, NH
I can't hear it over my MP3. :D The other day I was riding with my wife as pillion so I didn't have the tunes on, and when we were quiet I could hear a bit of noise from the front PR2 when cornering. Not real noisy, just a little tread noise.
Jim
010688
Not to hijack the thread, but for those of you with lots of expirience with the PR2s. How quiet are they? I have about 3000 miles on mine, and I while they are very quiet in the verticle, if I lean to either side any amount and I get a whine/humm. Is this normal? I've noticed it on very smooth quiet roads. The only time I hear the noise is when I lean the bike.
The whine or moan off upright is normal - it may even get worse if you hear it by 3000 miles.
Castle Rock Wa
All Michelin motorcycle tires that I have seen have a small barcode sticker on the bead , match this to the valvestem it is the lite spot. Once the tire is beaded up you cannot see this mark......you're welcome
Bigmak96
R.I.P. - 2021/08/07
Rural Mn
04 GL1800 Past tense
7910
I will be checking that out. My new PR2 has goobs of weight on it.:(
offsetcrank
any mileage reports from riding on 'tar and chip' roads?
my local DOT lays down hot tar, then crushed gravel. sometimes directly on top of fresh asphalt. ??????. they say it extends the road life.
any mileage reports from riding on these roads? have any of you experienced these roads thru the life of ur tyres?
anybody?
SteveST1300
Vendor
Ledgewood, NJ 07852
03&04 ST1300
5079
I have ridden on those PA roads that you are talking about I toasted a rear on them it should have had 2k left when I started the trip but by the time I was heading home the tire was toast. Those roads are rough on tires.
New Jersey
st1300 '04
7163
+1 on that.
Those oil spraying in use signs were never a good thing.
They were brutal thru 2" of gravel with a 23mm bicycle tire as well LOL.
lddave
been there
South Frydek , Texas
166
PR2 replaced today 12,799 miles . It was not down to the wear bars yet but too close for another trip . Replaced with Metzler Z6 .
Dave Bankhead
Fortunet 1
Fortunet1
Gilroy, Ca.
06 ST 1300
Dave Bankhead
So David....Why did you go to Metzlers after such a good run on the Michelin?:shrug2:
TMUS
MSF Instructor 32 years
Quincy, Michigan
2006 ST1300a(Marvin)
7054
Just replaced my rear PR2 with a PR3, had a total of 16,600 miles. No cords showing, but center was very easy to push in when off, the rim.
On at 42,300
Off at 58,900
Total= 16,600
