I need some help from any wranglers of elastic-trickery out there . Possibly a falorn hope, but if you don't ask you will never find out
My Pan had an alarm fitted to it by a previous owner which was modified by the dealer when they took it in part exchange and before I even saw it some 9 years ago
This summer I have been blowing the fuse on the Turn lights/Brake light circuit quite regularly, I blew my 4th since the beginnig of May, say over 6000 miles, which I think may be due to the insulation around the repair on the loom when they took the alarm off breaking down. The dealer has long since shut up shop, so at least to give be a chance to trace the joint down , around 12 years ago was there a favorite place to wire an alarm into the turn light circuit so the indicators flashed when the alarm was set off ?
All brake and turn lights are working normally otherwise so I don't think it is a bulb drawing too much blowing the fuse (only a 10a fitting) although I don't know if they have ever been changed so they may well be the original Honda bulbs as fitted by the factory.
Many thanks for considering this
