My right front turn signal isn’t working. The running light works but when I switch on the turn signal, the front light goes out completely. The right rear turn signal and indicator on the gauge panel flash rapidly. They flash normally for left turns. The left turn signal works properly. I tried replacing the right front bulb but that’s not it, the bulb is good.
This problem came up after I replaced my engine sub-wire harness, thermostat, and most all the coolant hoses so I had the bike torn down quite a bit. The engine bay was a mess, so I did a lot of cleaning. There is a large connector on the left side of the bike frame just in front of the ignition coil and cylinder head. That was covered in grime so I cleaned that as gently as I could but I’m wondering if the turn signal wiring runs through there?
I’ve studied the wiring diagram, but the turn signal switch confuses me (diagram attached). I see the orange and light blue wires going into the switch, but those wires don’t appear to be switched so I’m guessing that is the running light connection. I see the orange/white and light blue/white wires going into the switch and that looks like what’s switched but the symbols are PO, PL, and PR. What does that stand for?
I’d be grateful if someone could explain what the Turn Signal Switch Continuity diagram shows.
Which wire should I be focusing on for the non-operational right turn signal? Anything else I should check?
