Hi guys, need help to solve a problem on my 97' ST 11.
Situation:
Bike starts normally without choke.
Runs normally until 4k RPM and the bike starts to run rough, sputtering or misfiring.
The RPM is still able to climb up despite the rough running.
The coolant temperature also rises to mid position during normal riding speeds of 90-100km/h. (Previously was 1/8 of the operating range)
All the above happened one fine day on this daily ridden bike without any major service done.
Bike:
Side stand switch removed and wired accordingly.
Vacuum shut off valve bypassed and removed.
Engine oil and oil filter changed.
Radiator flushed and new coolant in the system. (Did this first as the temperature of the bike was running higher than normal)
Thermostat was already removed and the coolant flow is strong.
Nothing helped to fix the temperature problem.
That is until I opened up the air box and stuffed each air intake tube with a rag while the engine was running.
Sitting on the bike, the right hand tube openings had zero response to it being stuffed with the rag.
But the engine cut off when the left hand tube opening were covered by hand only, even without the rag.
Given the right hand tube openings means left hand carbs, the left hand carbs must have a vacuum leak since it does not depend on the tubes for air.
This is also consistent with the higher temperatures due to a lean condition in the left bank of the engine.
I have sprayed WD40 around the boots and the idling did not change. So my best guess is the left carbs are drawing air through a torn diaphragm.
Is there anyway to test if the diaphragms are leaking apart from taking the carb out as I still need the bike to go to work daily.
Or is there anywhere else I need to check that could be leaking air?
Or is there other things I should check before diving into the carbs?
Sorry for the long winded post. I am hoping to fix up the bike by this weekend as I am going for a ride next week.
Thanks in advance for all advices rendered. Your input is greatly appreciated. If not for this forum, I wouldn't have gotten to test for vacuum leaks and keep trying to diagnose the temperature problem.
Bear
Situation:
Bike:
Bear
