woodybelle
I just finished replacing 4 shims on my ST1300. I had 2 intakes at .004" and 2 at .005". I wanted all these to end up at .006". The shims are available from Honda in .025mm increments which is very, very close to .001" increments. So to get .002" more clearance you just need to get shims 2 sizes thinner than the ones installed. To get .001" more clearance just go down 1 shim size. I see no need to use the formula, which seems to cause confusion when conversions are done from metric to standard. There is a list of all available shim sizes and their part numbers in STWiki which will help you select the proper shims. I hope this helps make a simple matter simple. Just remember that Honda rounds the sizes up and down so a 198 shim is actually 1.975 etc.
