Water pump ST1100 vs ST1300
increasing
Oslo, Norway
ST1100AX
I see that oil can come out of the drain hole on the water pump on the ST1300 when the seal against the oil-lubricated bearing becomes poor.
Surely that can't happen on the ST1100... or?
As I read these pictures, there is no possibility of oil leakage in or in connection with the water pump on the ST1100 that can occur on the ST1300. I'm not thinking of oil leaks elsewhere that could get into the cooling water.
That's true, but compared to the ST1300 on the ST1100 no oil comes out of the drain hole on the water pump.
on pre '95 models a leaking oil cooler might cause such... in theory... never heard of one failing though...
or of course a defective head gasket on any 1100 model year... also rare though...
ST1100 w/pump has one weep-hole to protect the t/belt & drive, designed that "leaks" behind the pump case (shown in your first photo)
ST1300 w/pump features two weep-holes, one on the drive/oil side of the shaft, the other on the coolant side; both also venting outside to prevent contamination of lubricant and/or coolant media...
