Thanks I thought I read somewhere it’s better to vacuum pump it through then finish of with the normal way,something about the vacuum pump pulling through the pcv and smc better or is this incorrect ,I’ll be replacing smc and rear caliper pistons then givin the system a full fluid change ?Motion Pro Hydraulic Brake Bleeder if you want something cheap and effective.
Mighty-Vac vacuum brake bleeder if you want to get a little fancier.
Or you can just do the old fashioned way by opening each bleeder nipple one at a time and pumping the handle/pedal as required.
All three methods work and will get the job done equally well in my opinion. It is just a matter of convenience. The check valve or vacuum bleeder make it easier if you are doing it by yourself. The vacuum bleeder makes the flushing part easier as it is a breeze to run as much new fluid through the system as you like with very little effort.
A vacuum pump is faster, and that alone might be worth it to you. My old body tends to complain a bit if I have to pump the brake lever, squat by the bleed nipple, get up again, etc. With my vac pump (a homemade setup using a vac pump that is used to service air conditioning units) I fill the reservoir w/ fresh juice, squat once and bleed it through one caliper's bleed nipple, refill and go on to the next. Two knee bends per location.A vacuum pump does not get you a better result because it is a superior process. If it gets you a better result it is because it is easier to run greater volumes of fluid through the system and It also makes it easier to manipulate the SMC and to exercise the piston while the fluid is running through it - especially if you are doing this alone. This only equates to a better flush than doing it without a vacuum pump if you don't run a sufficient amount of fluid through the system because without the pump it is more difficult and time consuming so you got lazy. If the proper procedure is followed and a sufficient amount of fluid is pushed through the brake system doing it manually you will get the same result. All things being equal the vacuum pump is a convenience item to facilitate the job but in my opinion does not yield a superior result. I used a vacuum pump because I know someone who has one that I can borrow. If that was not the case would I go out and buy one solely because I believe it does a better job? The answer is no. Would I buy one because it makes it easier when you are doing this alone? After having used one the answer might possibly be yes. The reason is not because I believe it does a better job however. The reason is the number of vehicles I have to maintain and the fact that I am always doing this alone. If the decision was being based on use for the ST1300 only the answer is no.
