RobbieAG
Robert
Background:
Around 4 years ago I started having trouble with the fairly common "goes up but not down" issue. I did the clean/lube procedure and it was working well for about a year. About 2 1/2 years ago, it started acting up again so I did a full test per the service manual and everything passed (assuming the procedure was correct - see inconsistencies below). Shortly after, I replaced the windscreen adjuster assembly with a brand new one. It had been working fine until recently where it started exhibiting the up but not down symptom again.
Recently:
Tried cleaning the handlebar switch but it didn't help. Running through the tests again (pp. 22-32 thru 22-36 in FSM), there are inconsistencies between the service manual and my bike.
1) Screen adjust motor inspection - pass
2) Continuity inspection 1 - pass (but manual says there's a 6 pin white connector and a 9 pin black connector. My bike has a red 9 pin connector, a black 9 pin connector, and a white 4 pin connector)
3) Continuity inspection 2 - pass
4) Continuity inspection 3 - pass
5) Power circuit inspection - pass
6) Ground circuit inspection - all 4 green wires have continuity (on my bike there are 2 green wires to each relay connector). This is confusing because both answers to the "Is there continuity?" question indicate an issue. Yes is faulty screen up/down relays. No is open circuit in the green wire of the wire harness. What is the normal condition?
7) Screen adjusting switch test - manual says there's a 6 pin white connector and a 9 pin black connector. My bike has a red 9 pin connector, a black 9 pin connector, and a white 4 pin connector. Following the instructions by wire color, it passes the test, though I'm testing the continuity from the black to the red connectors.
8) Screen main relay - pass
9) Screen up/down relays - the service manual specifies connections to the green connector. On my bike there are 2 green wires to each relay connector. One passes the continuity test without battery to the orange/black or orange/blue connectors. The other passes the test when the battery is connected (pink/yellow or pink/blue).
10) Screen adjust motor - pass
After the tests above, I tried switching the up/down relays to see if it would make a difference. Both behaved the same way - it worked briefly both up and down, then stopped working at all.
Has anybody else experienced the inconsistencies I've noted above? Any ideas what to try next? I'm tempted to go ahead and buy an new switch and relays but I'd rather not spend money needlessly. Thanks in advance.
Recently:
