Just thought I'd pass on an experience I have had with splicing wires.
About 8 years ago I made a set of 4 inch handlebar risers. I then needed to lengthen the wires going to both handlebar switches. I used a standard soldered butt splice, like the right splice shown below. Everything was fine until about 2 years ago. I had a problem with the starter turning over, but no spark. It turned out the one splice for the run / stop switch was broken where the end of the solder met the unsoldered wire strands. I made a repair and everything was fine until a few weeks ago. I went out to start the bike, but the starter wasn't being energized because of another broken splice for one of the wires going to the starter switch. I repaired that break but then the headlights weren't working. Yup, another broken splice for the wire going to the N/C contacts in the start switch. Apparently while repairing the splice to the start switch, I stressed the splice for the headlights and caused it to break.
So all the splices were failing where the solder stopped at an end of the splice. Apparently, this is a stress point and will fracture eventually over time. Unwrapping the electrical tape from the bundle, and moving the wires around while repairing the broken splice caused the other splice to fail.
So I re-did all the splices, but used the left splice shown below. I think this technique will be more reliable for a longer period of time. the splices were covered with two layer of heat shrink tubing. I'll report back in 10 years with an update ( if I'm still respirating at that time ).
