DakotaJoe
You can call me Scott
I've seen the new black body panels that cover the tensioner/relay area and the battery side and wanted to put them on my 06. They were fairly cheap to purchase at the Honda dealership (around $27 for the pair)83410-MCS-D90 and 83460-MCS-D90
These are made to just click in to the new bikes but not mine. So I found an easy way to mount them that took about 45 minutes to do.
I cut the battery/fuse holder portion of the new right side plastic. (Save that piece for the other side.) Then I attached Velcro to the battery plastic and along the bottom of the new plastic and attached the other side of the Velcro to its corresponding area. That side was done.
The other side was a little trickier because there is just open space behind that cover. I sawed the leftover bit from the other side into several pieces and of those, I kept two. See the pictures for how it was cut and which to keep.
I shaved off the clip type edges and rounded the back of the right angle piece to conform with the relay plastic cover. For the left side I drilled a hole on the uncurved side to slide it over the existing screw hole (about a 3/8") so it would seat around the protruding frame. I temporarily attached it and put a rivet in the right side so I could align the plastic over the two and drill some holes for some low profile screws.
I screw it on and put on the side Tupperware and done! Looks great. I did modify mine around the spring tensioner as I have a 12V plug right next to it and I still wanted access to it.
I have posted the pictures with more descriptions and a bit of a numbering system in the event someone wants to try this out. See my albums for this and other modifications.
