Brake light works with front brake, not rear brake?
Seattle, Washington
2007 ST1300
The brake light activates when I use the front brake, but when I use the rear brake it does NOT light up!
Any good guesses on what may be causing this to save me some time troubleshooting PLEASE...
Thanks in advance!
Sadlsor
Birmingham, Alabama
2008 ST1300A
9065
Check the rear brake bulb?
Check the brake switch (pedal depresses plunger I think) behind the brake pedal?
Fuse under the left side cover?
I'm not used to having to think, this far from lunch time...
Richmond, VA
'01 & '96 ST1100s
9007
If the front switch works the light, then the problem must be at the rear switch.
Added: The two switches are wired in parallel, so they share the same fuse, etc.
Either the switch is bad, it's not being activated, or one of the wires is disconnected.
Start by looking at the pedal movement and whether it's pulling on the spring.
Added: Check the switch itself by pulling directly on its plunger rod.
Montreal
2009 ST1300A9
If the brake lights illuminate when the the front brake lever is pulled this means that the bulbs and fuses are all good. It also means that all of the wiring is good with the exception of the section of wiring between the rear brake pedal light switch and the brake lamp harness.
The simplest test is to unplug the switch at the brake pedal and jump the wires to see if the brake light illuminates. If it does, everything after the switch is good and the problem is either a defective switch or one that is not being activated by the mechanism. If it doesn't, there is a problem with the wiring between the switch and where those wires join the main brake lamp wiring harness.
