- Joined
- Oct 26, 2020
- Messages
- 1,768
- Location
- Makefield Highlands PA
- Bike
- 2016 ST1300P
- 2024 Miles
- 003902
Did a full LED conversion a while back, after 60K miles only on low beam failed and it was intermittent. In that conversion was the 6000k 194.
They have not failed, but a burn marked appeared after a while, after removing, the spot is only where you see it.
I haven't touch since installing, thought I should investigate and maybe try a newer version... so I did.
You can notice less glare around the top, this may or may not be good. I only changed the left bulb. I will see in different conditions if I like them.
