What is it's function?
What effects will occur if system is removed?
Who has removed Pair and what was the results?
Ride Safe
Ride Safe
Verify system actually works. Most people definitely report changes under deceleration when removing.I took mine out but kept all the parts and if I’m in there again, I think I will put it back. Cleaned it up, there was a canister that had a thick oily substance that I cleaned up. I thought it would stop some of the “gurgling “ and popping when decelerating but nothing changed.
Function: reduces polution. Description and schematic in Chapt 1 of the Honda Service ManualWhat is it's function?
Ride Safe
Aren't the adjusters air-screws rather than fuel-screws, meaning that open farther does lean the mixture?(except the PAIR tech complaining that both are running too lean... in real both are set to 2 1/2 rotations out instead the 2 1/8 given for the AR (Austrian) code...)
They're pilots, tipped end in the supply to the idle-jets...Aren't the adjusters air-screws rather than fuel-screws, meaning that open farther does lean the mixture?
Methinks its an air-guide, shielding the carbs(bowls) from the engine heat...Thank you, all Another question, What is the purpose of the rubber diaper under the carbs? Is it needed? Ride Safe
I removed mine over 10 years ago. I left the chrome piping at the exhaust header (Chrome looks good) and replaced with an exhaust worthy gasket to seal the tube. This way I did not have to worry about future leaks. I agree the purpose is to improve emissions, I'm not sure that can be proven!What is it's function?
Ride Safe
You are probably right about the shape of the diaphragms - It has been quite a few years ago when I replaced them and I've rebuilt many different kinds carbs since then.Dan, I think you’re referring to the air-cut valves, but they’re not triangular. If the PAIRs pass the function check in the manual, the troubleshooting instructions then point to the air-cut valves as a possible source. Did you perform the check on your PAIRs system before removing them? If they didn’t pass, did you take the air suction valves apart and inspect the diaphragms? How’d they look? Just curious…
That’s why I removed 2-Bros mufflers on my bike. The deceleration popping was too annoying. That and louder volume was more than I wanted.You are probably right about the shape of the diaphragms - It has been quite a few years ago when I replaced them and I've rebuilt many different kinds carbs since then.
At the time I just blocked off the pair ports to see how it ran without them. I wasn't in search of any power improvement at the time but just was trying to reduce the deceleration popping etc.. That popping was pretty annoying especially being I had installed Delkevic mufflers and the popping was louder than with stock mufflers. After that I removed the pair piping altogether mainly just to simplify access etc. If I remember correctly some of the hoses were degraded pretty badly that connected to the chrome pair piping.
As far as performance - the pair system has no effect on the running of the engine as you and others have said. All it does is introduce air into the exhaust ports to allow complete burn of unburned fuel in the exhaust. The air-cut system probably has more to with keeping the exhaust clean than anything - there was a huge reduction with engine burbling and popping during deceleration after replacing the air-cut diaphragms and springs. I am assuming this was because the fuel was cut off when the throttle was closed so the unburned fuel was not igniting in the exhaust header during deceleration.
After installing the Delkevic mufflers I too found them to be too loud. I found out that Delkevic made quiet inserts for the mufflers which I installed. Those inserts made the sound very tolerable and very slightly louder than stock with a deep tone that was just fine. The weight difference between the Delkevic and stock mufflers was huge.That’s why I removed 2-Bros mufflers on my bike. The deceleration popping was too annoying. That and louder volume was more than I wanted.
It doesn't shut off the fuel flow, it shuts off the air flow, thus richening the mixture so that it will burn in the cylinder instead of the exhaust.There is another system that works in conjunction with the pair system that really effects the deceleration burble and backfire, It is built into the carb bodies. I don't have a manual in front of me right now but it uses small triangular diaphragms and when the throttle is closed and intake vacuum peaks, it shuts off the fuel flow through the jet system. When I had my ST1100 it was starting to burble and backfire quite a bit and thinking that it was the pair system I disabled it. That helped a little bit, but it did not stop the problem, so I rebuilt the carbs and replaced the diaphragms and springs on this vacuum fuel cutoff system and all burbling and backfiring stopped completely. I bought a complete kit with the diaphragms and springs for this from some aftermarket house, it's been so long I don't remember where I got it.
