With hoses and bolts removed I lift the radiator up to clear the lower pin the fan hits the frame and prevents removal. Manual states remove upper body panels to much effort. Must be an easy way. Any removal suggestions. Ride Safe Greg
It's been a while but I think you tilt the top foward then pull up.With hoses and bolts removed I lift the radiator up to clear the lower pin the fan hits the frame and prevents removal. Manual states remove upper body panels to much effort. Must be an easy way. Any removal suggestions. Ride Safe Greg
