You can select to search along your route, so it only displays what is coming up ahead.I think the 550 searches for stuff using a circle where you are the center so the 10 miles gas station might be behind you ..
Thanks, I couldn't remember if it did.You can select to search along your route, so it only displays what is coming up ahead.
I believe the XT's memory is 32 gig, and you can add a micro sd card - I've added a 32 gig SD, it might take larger...I don't know. That 32 gig should handle a few trips....around the world.I can't remember the 550 memory but on the XT you can load the entire U.S...
I was able to get all of North America on to my Zumo 550 internal memory until a few updates ago. It eventually just became to big and I had to go to an SD card.I think the XT is the first Garmin I've ever owned - I must have 6 or so left, through the years - that held the Lower Forty- Eight without adding a card.
