I would seriously consider a different dealer. I also would not believe a word said by anyone there at this point. The manager will back his tech unless he looking for an excuse to get rid of him. I would see it as an expensive lesson. Move on to a different dealer or learn to do it yourself.
I can't say much about the 1300's maintenace as I don't know much about them. If Honda followed the 1100's lead, the 1300 will be about bullet proof. With you guys attitude on maintenance, I'll buy definitely buy an ST from someone here when the time comes. I do maintenance 40 hours a week so I'm not inclined to do it at home. Other than consumables (oil, filters, brake pads, speedo cable, shocks, tires) my ST is pretty much '96 factory stock. I have rebuilt the clutch master cylinder, replaced the speedo drive, radiator overflow tank and hose, and deleted the vav. fuel valve. The valves were in spec last time I checked. Being a tad north of 100K, I intend to do some maintence this Fall when the temps break. Scheduled is a timing belt, clutch, clutch slave cylinder, valve cover gasket, drive inserts on rear wheel, and some new rubber cushions on the foot pegs. I don't ride like an old grandpa. I wind it up every ride and bounce the tach needle off rev. limiter ocasionally.
