Hi,
Been working thru troubleshooting a rough running cold ST1100/96. It runs fine once warmed up, when cold it sounds like it's running on a couple of cylinders, disappears once warm and I mean at least close to operating temp.
I have been thru the carbs twice now, float level, cleaned twice, replaced low speed jets and tubes, resynced a few times, slide diaphragms all look good. I get a popping thru a carb or two when it's cold also.
What next?
Valve adjustment? I saw one thread where someone had a similar problem and disappeared after a valve adjustment. Coil maybe, but it runs strong thru redline. I acquired the ST with 39k and couldn't tell you if the valve clearance has ever been checked.
What next?
