- Joined
- Jun 21, 2011
- Messages
- 1,002
- Age
- 71
- Location
- Ada ( Grand Rapids ) Michigan
- Bike
- '07 ST 1300 & '91 GW
In the Installation manual where it says to hook up "Tach" wire to negative side of coil or tach wire , what terminal on a '07 ST's coil do you use ? Blue/Yellow (or Yellow/Blue) from the ECM or the Black/White also from the ECM & fuel cut relay, injectors, and bank angle sensor relay .
The ST's coils are also "negatively" grounded thru the coil housing according to ST 1300 wiring schematic.
I am planning to buy either a Dakota Digital or a Rostra non-vacuum unit ; they seem to be the same wiring.
